Thunderslut
- Joined
- Nov 3, 2013
- Messages
- 30
- Reaction score
- 4
Hello, this is my firt post on these forums, not sure if I'm even in the correct section.
HELP! My '05 R8 is posessed with a demon...
It just got set up at a local shop (not guitar center) because of buzzing, then when they were done there was more buzzing then before. I brought it back and they tightened the rod a bit, and loosened the bridge screws and still buzz..
fret - strings that buzzes (e as in low E)
1- e-d-g
2- e-d-g
3- e-d-a-g-b
4- a-d-g
5- a-d-g
6- d-g
7- d-g
8- d-g
9- d-g
10- e-d-g-a
11- d-g
12- e-d
13- d
14- d
15- d
16- d
17- d
18- d
19- d
20- d
21- d
22- d
some information:
brand new ernie ball regular slinkys.
the neck relief is perfect, when I capo the first fret and fret the 15th, a piece of paper can pass through the 7th fret on both high and low E.
i put a straight edge on the middle of the d and g strings on the fretboard, and the neck bends ever so slightly under the straight edge at the 3rd-15th frets, at max it reaches the depth of a business card near the 9th fret.
I attached two picture of bridge height, and string height (unfretted at 12th fret.) Each line = 1 mm.
I did not bother to tack picture of saddles, as my intonation is perfectly in tune at 12th fret vs unfretted.
Can all you fellow les-paulians please help me with the excorsism, we must remove the demons from this guitar immediatly.
1- e-d-g
2- e-d-g
3- e-d-a-g-b
4- a-d-g
5- a-d-g
6- d-g
7- d-g
8- d-g
9- d-g
10- e-d-g-a
11- d-g
12- e-d
13- d
14- d
15- d
16- d
17- d
18- d
19- d
20- d
21- d
22- d
some information:
