Muttering Bill
- Joined
- Mar 28, 2012
- Messages
- 688
- Reaction score
- 530
Right, but don't those other notes generally add up to an established scale anyway? It seems like it'd be easier to start with the scale and superimpose the chord tones over it.So - on any one chord - you can use the notes in that chord as the foundation and outline of your phrases, and if you want any other notes (which you probably will) they come from the other chords.
That doesn't prevent you from using chromatic approaches (half-step away from chord tones) is you want something bluesier-funkier-jazzier.
*snip*
Generally speaking, you rarely need to break all that down into its constituent parts. I'm usually aware that a particular tune might use (say) the G major scale (its melody and chords all come from that set of notes), but that's a kind of theoretical consciousness, an intellectual analysis. When I'm actually playing, I'm not thinking of that, I'm visualising the chord shapes on the neck, the way they link up, because they're my stepping stones. Without them, I'm wading in the stream..![]()
If I'm playing over that song in G major, then I know that while I'm over a G chord I need to zero in on the G, B and D, but I still have the rest of the scale to draw from as needed. Rather than constantly having to think, "Ok, I'm using G, C, D and Em chords, so what notes are in those..." If they add up to a G major scale anyway, why not just use the scale? Think of one chord at a time instead of having to consider them all at once.
Or is that digging in farther than you meant? One chord at a time and just grab a neighboring note as required?
I can't imagine being able to visualize 3 or 4 or 5 chords simultaneously across the fretboard. It seems overwhelming. I can't even do it with one. That's the CAGED system, right? I'm sure it's probably not as hard as it seems. You've been doing it so long you don't need to really think about it, the same way I don't have to think about how one scale pattern matches up with the next. But having ignored chords for so long it's an intimidating idea.
