Louie
- Joined
- Nov 2, 2009
- Messages
- 5,936
- Reaction score
- 10,436
Just thought of sharing this with everyone:
Last night I plugged in my freshly restrung LP Special into my 100% stock 2013 Marshall JTM45 Reissue, turned the amp on, waited for almost 2 minutes and when I turned the stand-by switch on, there was some static noise for a few seconds, no guitar sound whatsoever and immediately the amp died. The pilot light went off and there was no more sound coming out.
I pulled the fuses out and the mains fuse was blown. I replaced it with a new one, turned the amp on again, waited a minute and as soon as I flicked the stand-by switch on, the amp died again.
After browsing a few forums last night, it seemed that one cause might be the rectifier tube. This morning I bought a new JJ GZ34, put it in along with a new mains fuse, turned the amp on and everything was ok.
I'm glad it wasn't anything more serious, but it seems there's a known issue with the stock GZ34 that Marshall uses.
If you have a similar problem, check your rectifier tube first. But my concern is, could there be another component that's causing the rectifier to fail?
Cheers,
Louie
Cheers,
Louie
