SG Lou
- Joined
- Apr 3, 2009
- Messages
- 2,676
- Reaction score
- 1,842
Im going to attempt to build a 56 LP Custom Replica for myself. I have always loved the Custom and something about the Alnico V pickup makes the guitar look even cooler.
Now for the REAL reason of building it. A few yrs ago Bill Fischer was offering the Forum a deal on Mahogany body and neck blanks. So I jumped on the offer with the intent to build a 59 Replica. In the process of cutting and routing and not paying attention I SCREWED the template to the back of the body blank to route out the control cavitys. Stupid mistake but now I was left with 2 screw holes in the back of the body.
NOT GOOD if your going to build a Standard. So after some debating I decided that
Ill veneer the back to cover the holes and build a Custom instead.
OK, Enough with the chatter, on to the pics !
Back of body showing the veneer.
Yes its a separate Mahogany top. Like I said, this started out to be a Standard with a Maple Top. I got a piece of Mahogany off of ebay and had the guy resaw it for me
so I can have a ¾ thick piece for the top. He also sent the remainder which turned out to be just a hair less then ¼ thick. Little did I realize that Ill be incorporating THAT piece into this build More on that later.
Nasty tear out which I was able to repair. Again, its going to be painted Black so no one will see it ! ( I HOPE ! )
So in my haste to get going on this I did not shoot any pics of the actual routing / contouring of the top or doing the neck plane routing. Sorry !
Back of body showing Binding route completed.
Notice the difference in color and grain pattern between these 2 pictures of the back?
I didnt like the look of the veneer so I ran the body through the Thickness Planner, took off the same amount of wood as the binding is thick and glued up that left over ¼ piece I had from the top wood to the back. Once it was dry I shaped it and routed out the cavity openings.
( OK, so this build is already far from being ACCURATE ! )
