Righty tighty .... lefty loosey.
Clockwise tightens.
Make sure you put the washer back on.
Don't over tighten.
You should never turn a truss rod nut more than a 1/4 to 1/2 a turn at a time.
Wait til overnight for it to take new shape after adjusting.
No, the truss rod is held in place by design. All you should need to do is put the nut back on. Careful not to cross thread it.If The truss Rod is loose, wouldn't You need to remove the fretboard in order to reconnect them?
The nut and the thread are both sitting there in the trussrod cavity. The TR isn't a bungee cable either. It doesn't spring back into the neck out of reach once there is no pressure on it.If The truss Rod is loose, wouldn't You need to remove the fretboard in order to reconnect them?
