The burst
  • Thread starter bonanza2252003
bonanza2252003
THE FIVE FACTORS WHICH CREATE THE ‘1959 BURST’ SOUND
Posted at 00:40h in Blog, Guitar Reviews, Premium, Reviews by SoloDallas 12 Comments
0Likes
“Various factors all came together in 1959 to produce what I, and many others, consider to be the ultimate electric guitar, the 1959 Burst. I have spent 38 years studying genuine 1950’s Bursts and reproducing their sound. I have found that there are five main factors responsible for creating the 1959 Burst sound”
THE WOOD
“The Honduras mahogany used in the 1950’s to build guitars was cut from trees that were hundreds of years old. This wood is often referred to as ‘old growth’. It is a very excellent carving wood. Due to its popularity with furniture makers, boat builders and guitar makers, it is now gone. Used up. The mahogany available now is grown on plantations. For whatever reasons it is very different from old growth mahogany. It might as well be considered a completely different type of wood. I have experimented with it and found it to be very unsatisfactory for reproducing a true 59 Burst tone compared to ‘old growth’ Honduras mahogany”
“Since about 80% of the wood used to build a Burst is Honduras mahogany, this is obviously the most important wood contributing to the tone. I used only old growth Honduras mahogany from the 1950’s just like the 1950’s Bursts were built from. I used old growth Brazilian rosewood for my fretboards and Eastern hard maple for the tops”
THE GLUE
“There are four basic pieces of wood that make a Burst style guitar. The fretboard, the neck, the body and the maple top. Obviously then there are three basic glue joints between the nut and bridge. One is between the fretboard and the neck, another between the neck and body and the third is between the body and the maple top. In order to produce good tone these four pieces must resonate as one”
“For hundreds of years musical instrument builders used ‘hide glue’ to build guitars. Hide glue was still used in the 1950’s. This type of glue soaks into the wood and hardens to a glass like consistency. It leaves a minimal film between the two surfaces being joined. Since it dries to a glass like consistency it resonates with the vibrations in the guitar”
‘If you hold up a piece of glass and tap it lightly with a hard object it will ring. If you do the same with a sheet of plastic, the plastic will not ring, instead it absorbs the vibrations. The same principle is in effect with hide glue, brittle and glasslike, versus modern glues that are not”
“Modern glues do not penetrate the wood as well as hide glue. They leave a film between each piece of wood. Thus the four basic pieces of the guitar are insulated from each other. The vibrations traveling through the guitar between the nut and the bridge are muffled at all three glue joints. Modern glues kill the tone of the guitar. I used hide glue in the construction of these guitars”
THE FINISH
“In the 1950’s guitar manufacturers used nitrocellulose lacquer. This lacquer dries very hard and brittle. It becomes a resonant part of the guitar. Unfortunately it also chips and cracks more easily; therefore modern manufacturers don’t use it”
“Modern lacquers use plasticizers that keep the finish soft and flexible. The same principle of the resonance of glass versus plastic applies here. It would be the same as wrapping large rubber bands around an acoustic guitar. The rubber bands would absorb the vibrations of the guitar and deaden the sound. I used old style nitrocellulose lacquer (without plasticizers) on these guitars”
CONSTRUCTION SPECIFICATIONS
“During my 30 years experience repairing and restoring musical instruments, I had the opportunity to closely inspect many vintage guitars. Gibson, Fender, Martin, Rickenbacker, Gretsch, etc. Many were damaged beyond repair and consequently I was able to completely dismantle them and blueprint them. It is from this valuable resource of data that I am able to build guitars today”
“All specifications, dimensions, materials and construction procedures that contribute to the sound of an original 1950’s Burst are exactly duplicated in my guitars. Headstock angle, neck angle, scale length, neck profile, cavity sizes, etc., are all identical to an original 1950’s Burst”
THE PICKUPS
“The original 1950’s PAF pickup is definitely a very important factor in creating the ‘59 Burst tone. These can still be acquired from vintage parts dealers and are highly recommended. Presently I am using Lindy Fralins as I have found them to be very satisfactory compared to my reference set of original 1959 Double White PAFs that I have had since 1974″
SUMMATION
“A true ’59 Burst tone can only be acquired in one of the following ways. Buy an original 1950’s Burst for $200,000 – $300,000, buy a ‘57 or ‘58 PAF Goldtop for $100,000 – $200,000, buy a 1950’s Goldtop Conversion or buy one of my guitars”
“I think these guitars come the closest to reproducing a true ’59 Burst sound than any other”. – MAX BARANET
Thermionik
I know you are discussing the '59 guitars...
But would your opinions on wood, glue and lacquer hold for a '52 all gold Goldtop? I ask in case the build developed after the earlier models (7 years CAN be a long time in design development etc). I have stacked my Goldie side by side against 59's, and I would stick with my '52 - but then... I'm biased :cool2:
rockstar232007
Bullshit hyperbole from MAX, supplied with his very sub par replicas.
Yep.
I've played a couple of his replicas, that were touted as "as close to real '59 Les Pauls as you'll ever get" - they weren't anywhere near as good as any of the real '59s I've played. In fact, they weren't even in the same galaxy.
jerry47
0Likes
THE WOOD
THE GLUE
THE FINISH
THE PICKUPS
SUMMATION
So percentage wise, How far away in your opinion do you say a new top level R9 is way from a 50s LP? Just wondering.
Dick Banks
THE WOOD
No!....must resist, oh God no, please, not the dreaded.....here it comes....wait for it......any time now.....
RAG7890
Seriously?
There are a lot of MAX Guitars that are way overrated both Kits & Full Builds.
It is common knowledge amongst Replica lovers.
There are way better options.
That doesn’t mean however, that there are not some good ones.
:cheers2:
RAG7890
Each & every Vintage & Replica & Historic are different. Good & not so good amongst all of them & often just splitting hairs.
Then you need to look at the Harnesses used & the PU’s etc. etc. etc.
:cheers2:
  • Like
Reactions: BBD
jerry47
:cheers2:
I wanted him to answer i was expecting some ridiculous % number from him. Watching a Joe B Video the other day, Joe seems to think that a RI can get one 90% there or are 10% apart...however you wish to look at it.. In saying that Joe B is not the know all end all for me. But i believe Joe B. does have a very good working knowledge on what he's talking . I don't think he's pulling any punches.. In this video Joe covers many different topics @ 16:13 He starts talking about the topic that i am speaking to. Personally i tend to believe him. I've never heard a original 59 that blew me so far away over a Well build RI / Replica. Does a real 59 have a cool factor Hell yeah but....is it that much more of a guitar To me not so much.
Here's Joe B's video. His comment starts at around 16:13 and goes to about 17:55.
Thermionik
...Joe covers many different topics @ 16:13 He starts talking about the topic that i am speaking to...
Joe speaks truth - the signal actually passes through the pots and wires, and the socket. Make that signal path as good as you can get it and you start from a good place towards chasing the mythical tone so many seek. Sure, there's a hundred other factors, but it's "chain / weakest link / blah blah blah..."
Personally, "tone" is whatever suits YOU - not the masses nor the few... and feel is as important.
Jumping@shadows
If you cant notice an immediate, compelling and fundamental difference between an original ‘50s LP and a modern reissue, then vintage is not for you and there’s no point even getting involved.
Having worked around, played and owned scores of ‘50s/‘60s guitars, on the rare occasion I peruse the CS/Historic rack in a high end shop, I’m baffled how cheesy and clunky they are, and how crazy expensive!
PierM
0Likes
THE WOOD
THE GLUE
THE FINISH
THE PICKUPS
SUMMATION
What a pile of bullcrap LOL.
